Learn JMP Events
Events designed to further your knowledge and exploration of JMP.
Analyzing Reliability for Repairable Systems
Presented in English
Published on ‎11-07-2024 03:32 PM by Staff | Updated on ‎11-07-2024 05:42 PM
Learn how to pinpoint defects in materials or processes for repairable systems and identify design vulnerabilities so you can understand the best way to correct them.
Repairable: observations depend on the previous failure time. They are only independent when the underlying distribution is Weibull and beta = 1.
Nonrepairable: observations are independent (and identically distributed). When the underlying distribution is Weibull, this relationship holds regardless of the value of beta.
See how to:
  • Perform Recurrence Analysis for repairable components
  • Perform Recurrence Analysis with a grouping variable
    • Useful for extrapolation of system performance
    • Determine spare parts inventory needs, warranty risk etc.
  • Analyze Reliability Growth for concurrent or parallel repairable systems
    • Good for understanding how reliability has changed as a function of design changes
  • Use JMP Pro to create Reliability Block Diagrams to show reliability relationships among a system's components and illustrate how component reliability contributes to system success or failure
Q: Can I get confidence intervals/bounds for Recurrence Analysis?
A:  No, not visually.  However, you can specify a time or number of evetns and get confidence intervals on that using Specific Time for Cumulative and Specific Intensity and Cumulative options.  See below:
Start:
Fri, Jun 14, 2024 02:00 PM EDT
End:
Fri, Jun 14, 2024 03:00 PM EDT
Labels (1)
0 Comments
