JSL Cookbook - Archived
Building blocks of JSL code to reduce your coding workload.
The Crude MapQuest Call
Problem
REST interfaces are becoming more and more popular. Understanding this technique becomes very important for JSL programmers.
Solution
MapQuest uses this technique to provide information for geo-coding and routing. This function just encapsulates the call to MapQuest interfaces. You may use it for your own programs or just to see how it works.
See Also
Geocoding 2020
JSL Cookbook
If you’re looking for a code snippet or design pattern that performs a common task for your JSL project, the JSL Cookbook is for you.
This knowledge base contains building blocks of JSL code that you can use to reduce the amount of coding you have to do yourself.
It's also a great place to learn from the experts how to use JSL in new ways, with best practices.
