JSL Cookbook - Archived
Building blocks of JSL code to reduce your coding workload.
A routing function
Problem
Determine distances, travelling times and complete routings between pairs of addresses. Encapsulate the whole REST API functionality that is needed to get the routing information from MapQuest.
Solution
This script can be included in JSL programs to get routing information for pairs of locations. It is invoked through a function call and JSL variables and lists are needed to provide the necessary information. See my blog post for more detailed information.
See Also
Geocoding 2020
JSL Cookbook
If you’re looking for a code snippet or design pattern that performs a common task for your JSL project, the JSL Cookbook is for you.
This knowledge base contains building blocks of JSL code that you can use to reduce the amount of coding you have to do yourself.
It's also a great place to learn from the experts how to use JSL in new ways, with best practices.
