  • Learn some foundational elements of JMP Scripting Language (JSL) and how to extend point & click automation into repeatable, shareable routines. Register. June 26, 2 p.m. US Eastern Time.
JSL Cookbook - Archived
Building blocks of JSL code to reduce your coding workload.
Set and get credentials in the Credential Manager via PowerShell on Windows
Problem
You need to use a username and password in your script and you use Windows.
Solution
Call powershell via RunProgram to store the password in the Credential Manager (search for it in the start bar) so you can retrieve it later.
Names default to here(1);
loadmodule = "
		if (!(Get-Module -ListAvailable -Name CredentialManager)) {
			Install-Module CredentialManager -force -Scope CurrentUser
//Function to run command in powershell, strips trailing line breaks
RunPowershell = Function( {command},
	Regex(RunProgram(
		Executable( "powershell.exe" ),
		Options( {"/c", command } ),
		ReadFunction( "text" )
	), "^(.*?)[\r\n]+$", "\1")
// Set password
SetPass = Function( {target,user,pass},
	RunPowershell(
		"$target = '" || target || "'
		$usr = '" || user || "'
		$pswd = '" || pass || "'
		" || loadmodule || "
		New-StoredCredential -Target $target -UserName $usr -Password $pswd" -Persist LocalMachine
	1; //password is returned as free text, don't return the response
// Get password
GetPass = Function( {target},
	RunPowershell(
		$creds = Get-StoredCredential -Target $target
		$creds.GetNetworkCredential().Password"
// Get username
GetUser = Function( {target},
	RunPowershell(
		$creds.GetNetworkCredential().UserName"
You can delete these test credentials using the 'windows credential store'.
Ideally these credentials would never be stored in memory. You would call them at the moment they are needed, like this:
request = New HTTP Request(
	URL( "https://myserver" ),
	Method("GET"),
	Username( GetUser( undesc ) ),
	Password( GetPass( undesc ) )
Here is the powershell command these function actually execute:
SetCred:
param( $target, $usr, $pswd )
if (!Get-Module -ListAvailable -Name SomeModule) {
New-StoredCredential -Target $target -UserName $usr -Password $pswd -Persist LocalMachine
 GetCred:
param( $target )
Comments
FN
Great solution. Thanks for sharing.
JSL Cookbook
If you’re looking for a code snippet or design pattern that performs a common task for your JSL project, the JSL Cookbook is for you.
This knowledge base contains building blocks of JSL code that you can use to reduce the amount of coding you have to do yourself.
It's also a great place to learn from the experts how to use JSL in new ways, with best practices.
