JMPer Cable Blog
Open source database (PostgreSQL, MySQL/MariaDB, or SQLite) connection configuration using ODBC on a Mac
Do you need to connect JMP to an open-source database- specifically PostgreSQL - from a Mac? Below are step-by-step instructions, involving two main parts:
  1. Configuring the ODBC driver and manager.
  2. Establishing the connection from within JMP.
Follow these steps to ensure a seamless connection.
Step 1: Configuring the ODBC driver and manager
1.1 Download the driver:
  • Download the Actual Technologies ODBC driver from https://www.actualtech.com/download.php.
  • Important: This driver is a licensed software. Without a license, only the first three rows of your database will be accessible.
  • Tip: Download the driver using Safari, not Chrome, to avoid installation errors.
1.2 Run the installer
  • Double-click on the “Actual ODBC Pack.pkg” icon to run the installer.
Picture1.svg
1.3 Open the ODBC manager
  • Go to Macintosh HD/Applications/Utilities folder and double-click ODBC Manager.
1.4 Add a System or a User DSN
  • Click on the System DSN or User DSN tab and select Add.
1.5 Configure the driver
  • Select your driver (Actual Open Source Databases ) and click OK (see table below for note).
The table below lists which driver to choose based on the type of database you have:
Driver
Supported database(s)
Best for
Actual Access
Microsoft Access (.mdb, .accdb)
Legacy Access files, cross-platform sharing.
Actual Open Source
PostgreSQL, MySQL/MariaDB, SQLite
Modern, open-source database use cases.
Actual Oracle
Oracle database
Enterprise-grade Oracle database environments.
Actual SQL Server
Microsoft SQL Server, Azure SQL
Enterprise environments using SQL Server.
  • Click on Licenses to add your license keys (first-time setup). Without a license, only three rows of data will be accessible.
  • Give the Data Source a name and select PostgreSQL for type.
Picture2.svg
  • Enter the server IP address, port number, login ID, and password as show below.
Picture-greyed.svg
  • Choose the database you want to connect to from the "Database" dropdown menu.
  • Click Continue, then Test Connection to confirm everything works.
Step 2: Establishing the Connection in JMP
2.1 Create a new database connection
  • In JMP, go to File --> New --> New Database Query --> New Connection.
  • Select the Data Source Name (DSN) you created earlier.
  • Enter the username and password, then click Choose DSN.
Picture4.svg
2.2 Select Schemas and Tables
  • Browse the available schemas and tables and select those you want to query.
Picture5.svg
2.3 Build and run your query
  • Construct your query by choosing the columns you want to add, and any columns you want to Filter or Order By.
  • That's it! Your database is now connected and ready for analysis.
Picture6.svg
Last Modified: Feb 9, 2026 9:08 PM
Comments
Craige_Hales
Thanks! I ran into mysql and mariadb a long time ago when working with Wordpress and MythTV. More recently I ran into Postgres using Django to build a web site. It is really useful to peer into the database that makes a backend for another system; you can do analysis on the posts/users/changes/dates/etc. You will need to learn about the database schema: how is the table of users connected to the table of posts and the table of locations (for example) to make a map of where posts come from. (Old mysql windows post, may be out-of-date SQL for Cord-Cutters  .)
Getting connected to the database is the key!
