Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
JMPer Cable Blog
Created:
Jul 25, 2010 01:04 AM
| Last Modified: Feb 24, 2020 8:32 AM
A colleague recently ran into a problem after importing some data. The column names ended up in the first row of the data table. Here's an easy fix you may not know about. Click the image below to see how to fix this.
