  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
JMPer Cable Blog
A primer on functional design of experiments
Curve, or "functional," data is everywhere. It occurs whenever we measure something over a continuum, like measuring temperature over time, pressure gradient across space, or radiation absorption across wavelength. In the image above, we have particle size measured over time while milling pigment for making LCD screens.
Sometimes, the shapes of the curves we measure are important to us, and we want to know how curve shape is affected by certain factors. For example, how is the pigment size-over-time curve affected by how we run our milling process? That's a complex question, in part because curve shape is a complex thing. How do we figure out how some factors might affect it?
The answer: functional design of experiments. Watch the video below to see how it's done in JMP.
This video assumes that you're already familiar with the basics of DOE in JMP. If you're not, check out this on-demand webinar or, if you already have JMP and prefer a hands-on introduction, JMP's DOE Intro Kit.
Last Modified: May 21, 2020 12:29 AM
Comments
