Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
I wish the content for Row Legend would wrap and try to make a reasonably shaped/size box to go with its plot - like it does in graph builder but on bivariate.
I still think this is useful but it's possible to just use graph builder I guess. And nobody else has voted for it.
Here's what I meant: bivariate vs. similar effect in graph builder. If I want to include that plot in a larger report the legend can be useful in the right circumstances even with a long list of some attribute but it makes the report unwieldy because it's so tall. graph builder doesn't actively resize it but it does wrap it to work well with the default size of the plot anyway:
