csv export : add options
☐ cool new feature
☐ could help many users!
☐ removes something that feels like a „bug“
☑ nice to have
☐ nobody needs it
Besides text import ( Make decimal separator an option ) the text export from JMP is quite restricted compared other programs like Cornerstone and Python.
Please scan the options which are available in Python for text export and add the most useful ones.
e.g.
- specify field delimiter: Save data table with tab delimiter through script .. or via GUI.
- specify decimal separator
- export with and without header
- option: quote strings
Why is this idea important?
reduce the gap to other software.
4 Comments
hogi
Level XII
@Sarah-Sylvestre  [edited/updated comment - do you also get a notification?]
low prio -> can be closed and reactivated once the important ones are finished.
Hi @hogi, thank you for the update! I'm going to keep this open because other users have voted on it, but it is still valuable for us to know this is not a high priority item for you.
hogi
Level XII
hi @VKr are you OK to use a Python Script as a workaround. Then this wish can be closed.
VKr
Level I
Hi @hogi I'm fine with a workaround
