add lower and upper confidence interval option to Save Formula / Quantile in Parametrci Survival platform
In fit parametric survival platform only 2 options of equation can be saved:
  • save probability formula
  • save quantile formula
In majority of cases users of fit parametric survival platform are interested in equations of upper or lower confidence intervals for probability or quantile case.
I propose to add following save formula options to fit parametric survival platform:
  • save lower/upper confidence intervals probability formula
  • save lower/upper confidence intervals quantile formula
P.S.
The names in fit parametric survival platform are inconsistent:
  • time in profilers and Estimates of Survival is called time, while in Estimates of Quantile it called quantile
  • probability failure in Estimates of Survival and P in Estimates of Quantile
In fit parametric survival platform I propose to change:
  • name of quantile to time
  •  in Estimates of Quantile name of parameter P to probability failure
