  • See how to design an experiment, explore factor-response relationships, assess tradeoffs, and ID best settings. Register for Sep. 11 Mastering JMP.
Use Of Artificial Inteligence For Data Analysis
have an input where you tell JMP what your factors and responses are and it looks at all of the data and suggests which models would be best to look at first. I've put AI in the title but it also incorporates pattern learning machine and deep learning techniques.
This is essentially joining the neural network, model comparison and all other analysis methods into one interface. It could learn which methods & algorithms are best for the work an individual usually does and how the data is displayed as plots/ graphs.
SAS uses Machine learning so the knowledge is already within the company https://www.sas.com/en_gb/insights/analytics/machine-learning.html
David
1 Comment
Sarah-Sylvestre
Level V
Hi @d_barnett, thank you for your suggestion! We have captured your request and will take it under consideration.
