  • Use World Cup data to build models, explore spatial relationships, and create informative visualizations in JMP. Register. July 17, 2 pm US Eastern Time.
There is a shortcut to restart the previous operation, just like ctrl+E in minitab.
Similar shortcuts are set in JMP
Why is this idea important?
It can greatly facilitate the user experience.
6 Comments
jthi
I'm not sure what the minitab's shortcut does, but JMP does have Recall Last Platform
Open last platform in use
lehaofeng
Level V
The mac version does not seem to have this shortcut key.
stan_koprowski
Community Manager
@lehaofeng
On the Mac this is in the Window menu and has the keyboard shortcut Option-Command-L.
On Windows it's in the View menu and uses shortcut Ctrl-L. 
cheers,
stan
lehaofeng
Level V
Thank you very much, it does work in most scenarios, but it doesn't seem to work in an interface like the graphic builder.
bobmorrane
Level V
True, a lot of the changes you do in Graph Builder cannot be recalled.
