JMP Wish List
Table Join / Data Manipulation
In Table Join (and other associated platforms, as applicable), it would be helpful to provide a check box to automatically include the matched columns in the output table. This way, they don't have to be selected again for the set of columns that are to be included in the output table.
Thanks and regards
Mehul Shroff
3 Comments
StarfruitBob
I'm not quite sure what you're asking for, Mehul. I use functions like joining tables and concatenating usually multiple times a day.  When selecting the matching columns in each table in the Join dialog box, all columns are included in the newly generated joined table. Depending on the option you chose, these tables could have been merged into one or stay separated.  Can you give an example of what you're asking?
StarfruitBob
I apologize, I meant to say "these columns could have been merged into one or stay separated."
Hi @MShroff, thank you for your suggestion! We have captured your request and will take it under consideration.
