Surface profiler within a mixture design. Is it possible in JMP?
Dear community,
I have been using JMP for a couple of years and until now it is quite sad not being able to construct a 3D surface graph over a ternary plot within a mixture design. Before using JMP, I did this many times using another software and was quite easy so please could we have this feature in the next JMP version?
6 Comments
andrea_bat
Level I
Fully support the request of @CRMC
I learned that is possible to save a fit formula column i the data table; then plot it an a mixture plot from the data table and add contour fill.
Would be great to have it in the model window directly.
Hi @CRMC, thank you for your suggestion! We have captured your request and will take it under consideration.
SamGardner
Level VII
@CRMC thanks for the idea.  We are investigating this.  Could you let us know what the other product was that had this capability?
CRMC
Level II
Hello,
Thanks for taking the time to review this proposal. I used this capability few years ago in Design-Expert (Stat-Ease Inc., MN, US). Regards,
MaxiumumANCOVA4
Level I
I attended a LSSMBB course whereby our trainer used Minitab to teach in Mixture Design recently.  He is to show the surface graph once the Mixture design was constructed and after the response was collected.
