Saves the column order in a 2-way HCA clustering
In JMP version 13, when 2-way clustering is perform and displayed as dendrograms in HCA plot, one can only save row order by using "save display order" but not columns that often are variables. To get column order in current JMP version 13, one has to to go back to the data table, perform transpose and then re-do HCA with the exact parameter.  So it would be great if column order can be saved as shown in HCA plot in a similar way as one saves row order. Thanks.
