  • Sign-in to the JMP Community will be unavailable intermittently Dec. 6-7 due to a system update. Thank you for your understanding!
  • JMP 19 is here! Learn more about the new features.
Reorder entered factors when designing a DOE
I was walking an engineer through the Custom DOE platform. As part of our discussion, we decided to add a factor. The team wanted it to be the 2nd factor in the list of 5 factors, 4 of which were already carefully typed into the Custom DOE platform. We could not drag the new factor from the bottom of the list to the middle.
The engineer did not want to have to delete and reenter all of the factors. Given this, I did not suggest saving the factors table and reordering that.
We ended up creating the DOE table and moving the column in the table. But it was irritating. This seems like  simple thing to be able to do.
In Custom DOE and all of the other DOE platforms, I would like to be able to click and drag a factor (or response) up or down to another spot in the list of factors (or responses). This will save frustration, especially for those new to the DOE platforms.
