Recurrence analysis for only one system
Right now, when performing a recurrence analysis on one system, I still need to include a column in the "Label, System ID" role. There are some times where I would like to build an NHPP model on one a data set for only one system, but I still need to include a role here. The workaround is that I create a dummy column that just says "System1", but that is a pain.
I would like to see a check box in the options that says, "Only one system", which would then disable that role so that it's not required anymore.
Why is this idea important?
Creating a dummy column just so I can use this tool is a hassle and needless extra work.
