Process Screening: dynamically update fit chart
In the Response Screening platform, please can there be an option to update the fit chart when the selected row is changed?
At the moment (JMP 17.2), it's necessary to select the row of interest, then select "Fit Selected Items" from the red triangle menu each time.
The chart updating automatically will make it much easier to rapidly scan through long lists of parameters.
Example code attached (it's a bit hacky but demonstrates my idea).
Thank you.
