JMP Wish List
Problem with scale on prediction profiler when using almost similar Column names.
JMP version 17.1 PRO
I have a problem with the scale of the prediction profiler. The scale of "H" should be between 0.3 and 0.7. Suddenly it moves its target to 1.5 when I remove "h".
The problem happens when I remove "h". Before "h" was removed, the profiler was "normal".
The profiler seems to get confused by "h" and "H".
I would like some warning when two columns names are simuilar like "H" and "h" there could be problems when using them as a factor in a model.
Or better the problem fixed.
Why is this idea important?
I used a lot of time testing what is problem was.
