Presentation Autopilot (aka Workflow Builder 2.0)
☑ cool new feature
☑ everybody will want it!
☐ removes a bug
☐ nice to have
☐ nobody needs it
Table Scripts are useful, Column Switcher and Data Filters are helpful.
But - have you ever dreamed of having a universal control panel for your presentation?
In Jmp 19 (?) it will be available *)
*) if enough users support this wish with a Kudo.
You might know:
Enhanced Log/workflow Builder has two different ways how actions are recorded.
a) for Tables, every change is recorded as a separate step:
if a table is changed,
JMP does NOT record a script how to generate the current data table,
it just records how to get from the previous version to the current one
b) for reports, just the final version of the report is recorded:
if a report is changed, Jmp doesn't record anything. Just at the end ...
JMP         ....  records a script how to generate the current report]
Some days ago, @bswedlove posted the wishChanging a label should show in the Log
Let's start with this wish ... and think big - really BIG.
add a setting for the enhanced log/ workflow builder on which level to record the steps:
a) slim: just final scripts for reports (like now)
b) verbose: intermediate steps are recorded as well
What comes out: Presentation Autopilot
With the current Workflow Builder, a user can record his analysis workflow and use it again for the next data set.
With Presentation Autopilot (aka Workflow Builder 2.0), a user can generate an interactive, easy to use, fancy, impressive ...
Presentation Workflow.
He can start with a graph - and record whichever change he makes, group such steps and voila: he has an autopilot which can be used to interactively guide him through the changes of the graph, add variables, change colors, add labels, remove variables, replace variables, add a data filter, change the size, ...
Why is this idea important?
It will be sooo cool - everybody will want it!
2 Comments
hogi
Level XIII
Add-On:
Num-Enter as a shortcut
for "run the selected steps (... and select the next step)"
... similar to Num-Enter in JSL Editor
https://community.jmp.com/t5/Discussions/Workflow-run-selected-step/m-p/763104/highlight/true#M94410
Sarah-Sylvestre
Level V
