  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Non-Parametric Rank Correlations
What inspired this wish list request?   At one time there was a nice add-in, Correlate Y by X Add-in that computed both the standard Pearsons correlation along with Non-Parametric fits.  It was very easy to engage and worked well.  However, that add-in has not worked on the newer versions of JMP.  It is very common to use the non-parametric rank and the Spearmans rho for many applications.
Simply find a way to enable that add-in to work in JMP19
Why is this idea important?
Currently, the only way to access a non-parametric correlation to obtain a Spearmans rho value is the multivariate test platform.  That can work well if the number of variables is low.  But in many cases, the desire is to have a one by many correlation calculated.  And when the many are several hundred, the multivariate platform is simply inapproriate for that purpose.
3 Comments
scott_allen
Status changed to: Needs Info
@MKostura - Thanks for submitting the wish. Do you have a reference to this Add-In or it's name? We can ask the author if it is something that could update and publish in the JMP Marketplace
MKostura
Level III
@scott_allen.  The add-in name was "correlate y by x"  and the Add-In ID was "Parris-CorrelateYbyX" The version was 0.07    I have a copy of the add-in but there is no information that provides the name of the author although I do recall it was a JMP employee.  Does not seem to be a way to attach to this message.
The market place is, IMHO, a disconnected mess.  Not obvious how to connect easily from the community (it should be front and center on the User Community home page menu).  I stumbled on it after several minutes on the site.  And the market place has scrubbed a lot of add-ins that I still commonly use. I understand some may be deprecated (like the correlate y by x) but others were useful still.
scott_allen
