New Formula Column menu: user-Defined mini GUIs
☑ cool new feature
☐ could help many users!
☐ removes a "feels like bug“
☐ nice to have
☐ nobody needs it
If a user clicks on column/right click/new formula column/Transform/Scale Offset, a GUI pops up and ask the user for the parameters.
After pressing OK, a new column is generated with the respective rescale parameters:
This is very useful.
But there is no possibility to add user defined mini,GUI, like a
 column/right click/new formula column/Transform/Modulo shortcut to calculate Modulo the same way.
Please provide a functionality to gererate mini GUIs such that a user can add slightly more complex functions to the column/right click/new formula column menu which need a GUI.
Why is this idea important?
There are many wishes for additional functions to be added to the Column/right click/new formula columns menu,
e.g. add modulo to the NewFormulaColumn menu
@mia_stephens  suggested to generate the functionality on my own: https://community.jmp.com/t5/JMP-Wish-List/add-modulo-to-the-NewFormulaColumn-menu/idc-p/594368/high...(unfortunately, without a hint how to do so).
There was also no feedback from the community how to do it:
https://community.jmp.com/t5/JMP-Wish-List/add-modulo-to-the-NewFormulaColumn-menu/idc-p/596340/high...
So, I think that the needed functionality is missing.
With the possibility to generate user-defined mini-GUIs, users can add the functionality on their own and don't have to convince Jmp Dev Team to add the function.
