Measures of association also in the Fit Model menu
Now I have to calculate measures of association when fitting a Nominal Logistic Model by hand(Fit Model, module). But they are in the Fit Y by X model. Fit Model allows more flexibility and more independent variables.
Would it be possible to have these measures of associations that are now in the
Fit Y by X routine for nominal data, also included as far as possible in the Fit Model Routine if you run a Nominal Logistic Fit on Nominal data.
That would be very helpful and insightful.  If possible also add the Contingency coefficient and Cohen’s omega.
