Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
Suppose you have a function GetCurrentValue which gets the current value of user certain interface objects, and returns missing (.) for others. Suppose you have a list of interface objects (AllInterfaceObjects).
Depends on what kind of values GetCurrentValue returns. Suppose GetCurrentValue returns (checkbox << Get Selected Indices()) for checkbox items. If you apply IsMissing to the list of indices you do not get a boolean literal, you get a list of booleans.
!IsMissing({1,2,3}) = {1,1,1}
Because a list of booleans is not True, Filter Each will remove it! That means FilteredValue will not contain your list, even though your list was not missing.
Question 2
As you may or may not know, Create Database Connection is a function for creating database connections. It returns a database connection on success, and missing on failure.
Does this work?
connection = Create Database Connection(magicString);
if( !Is Missing(connection),
RunSomeQuery(connection),
Print("I have failed to connect")
