JMP Wish List
JSL Text Editor Color Themes
My coworkers were making fun of me for coding with bright backgrounds.  I could use another editor like Sublime or Atom, but JSL Text Editor does come with a lot of convient functionality.  Anyway we could include additional themes?  Preferably darker ones that are easier on the eyes.
15 Comments
In 14 (I think 13, too) you can change the elements in the theme under Preferences > Script Editor.  At one point I had mine set up with the Solarized Theme (link).
msharp
Thanks @MikeD_Anderson but I was aware of this.  However, the interface is clunky and requires changing every detail--which hardly constitutes a theme.  If you could perhaps share the JSL code to recreate the Solarized Dark theme, I would appreciate it.
Here's what I had previously - it may take some tinkering to get it to work.  It looks like every element now has two colors (foreground and background), but this should get you started.
Solarized Dark
Preferences(
	Script Editor Settings(
		Text Color( {131, 148, 150} ),
		Back Color( {0, 43, 54} ),
		Disabled Back Color( {0, 43, 54} ),
		Comment Color( {133, 153, 0} ),
		String Color( {88, 110, 117} ),
		Number Color( {42, 161, 152} ),
		Operator Symbol Color( {88, 110, 117} ),
		Operator Name Color( {38, 139, 210} ),
		Identifier Color( {88, 110, 117} ),
		Brace Color( {203, 75, 22} ),
		Guide Color( {88, 110, 117} ),
		Show Line Numbers( 1 ),
		Wrap Text( 1 ),
		Color Unknown Object Messages( 1 ),
		Save And Restore Document State Information( 1 ),
		JSL Code Folding( 1 ),
		JSL Code Folding Marker( 2 ),
		Allow Additional Code Folding Keywords( 1 )
Solarized Light
Preferences(
		Text Color( {101, 123, 131} ),
		Back Color( {253, 246, 227} ),
		Disabled Back Color( {253, 246, 227} ),
		String Color( {147, 161, 161} ),
		Guide Color( {147, 161, 161} ),
		Wrap Text( 1 ),
msharp
Thanks for sharing the code.  I spent some time trying to change colors with the preferences and the new system is much too complicated.  Changing colors and using Get Preferences didn't give me any valuable information either.  Since I don't know the structure of JSL Text Editor Object, there's no documentation for it, and Get Preferences doesn't return anything useful I believe I am unable to complete this task on my own.
Hi @msharp,
The Script Editor colors are actually managed in a preference file called JMPStyles.PFS and cannot be retrieved using Get Preferences() or set using Set Preferences().
I have gone through and created dark theme that looks like this:
Unfortunately, the downside to this theme is that the blinking text cursor is still black and can be difficult to see.
I have attached the JMPStyles.PFS file for this theme. You can place this file at "%AppData%\Roaming\SAS\JMP\14" on Windows to apply the theme after restarting JMP.
However, I realize this is not a perfect solution and I will pass this along to our development team for review for a future release of JMP.
Thanks,
Justin Chilton
JMP Testing
Edit: I realize now that these comments to not allow for attaching files. I have included the text you can include in the JMPStyles.PFS file below.
//*** Generated Text, Editing this incorrectly may risk not being able to start JMP ***
Styles(
	JSL(
		Default Enabled(
			Foreground Color( "White" ),
			Background Color( "Medium Dark Gray" )
		Default Disabled(
			Foreground Color( "Medium Light Gray" ),
		Block Comment(
			Foreground Color( "Light Green" ),
		Nested Block Comment(
		Line Comment(
		Brace(
		Date(
			Foreground Color( "Medium Light YellowGreen" ),
		Error( Background Color( "Medium Dark Gray" ) ),
		Plain Text(
		Unknown(
		Identifier(
		Message(
			Foreground Color( "Light BlueCyan" ),
		Message Unknown(
			Foreground Color( "Medium Light Red" ),
		Number(
			Foreground Color( "Medium Light Green" ),
		Operator Name(
		Platform Name(
			Foreground Color( "Medium Light Orange" ),
		Operator Symbol(
		String(
			Foreground Color( "Light Purple" ),
		Block String(
			Foreground Color( "Medium Light Purple" ),
		Annotation Note(
			Foreground Color( "Medium Dark Gray" ),
		Annotation Warn(
			Background Color( "Gray" )
		Annotation Error(
			Foreground Color( "Light Fuchsia" ),
		Annotation Fatal(
		Line Number(
		Brace Light(
			Foreground Color( "Light BlueGreen" ),
		Bad Brace(
			Foreground Color( "Light Red" ),
		Control Char(
		Indent Guide(
	Log(
		Default Enabled(
		Default Disabled(
		Block Comment(
		Line Comment(
		Default Background(
		Log Submit(
		Log Output(
			Bold( 0 ),
		Log Output Start(
		Log Output End(
		Line Number(
			Background Color( "Medium Light Gray" )
		Brace Light(
			Bold( 0 ),
		Bad Brace(
			Bold( 0 ),
		Control Char(
		Indent Guide( Background Color( "Gray" ) )
msharp
 Wow Thanks!  I do look forward to a smoother solution in the future, but this makes me and my eyes super happy!  My colors are slightly different, but that's probably b/c I'm on JMP 13 still (or maybe windows 7?).  B/c of this it's not hard to see the cursor at all since this grey is much lighter.  But if themes are included in the future, lets be sure to change the cursor color as well!
I copied the code where applicate for the Log, but wasn't sure what to do for the values: Log Submit, Log Output, Log Output Start, Log Output End, or Call Tip?  This isn't important, I really appreciate your feedback.
Thanks for setting things straight, Justin!  This is a really nice color scheme.
m
Check out my updated post above. I have added colors for a decent looking log.
Here's a screenshot of what it looks like on my computer:
This also works on Mac. Go -> Go to Folder -> ~/Library/JMP/14. Then you can add-in that JMPStyles.PFS file that Justin has above.
Nice -- Thanks Dan!
