%3CLINGO-SUB%20id%3D%22lingo-sub-673386%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EJMP%20Live%3A%20permisos%20de%20nivel%20posterior%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-673386%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3E%3CSTRONG%3E%C2%BFQu%C3%A9%20inspir%C3%B3%20esta%20solicitud%20de%20lista%20de%20deseos%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EA%20menudo%2C%20peque%C3%B1os%20grupos%20ad%20hoc%20entre%20equipos%20quieren%20explorar%20datos%20juntos.Hoy%20en%20d%C3%ADa%2C%20estos%20deben%20estar%20en%20espacios%20separados%2C%20eventualmente%20pueden%20estar%20en%20carpetas%20separadas%2C%20pero%20en%20ambos%20casos%20eso%20significa%20que%20la%20%C3%BAnica%20forma%20de%20organizar%20las%20publicaciones%20se%20basa%20en%20los%20permisos.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%C2%BFCu%C3%A1l%20es%20la%20mejora%20que%20le%20gustar%C3%ADa%20ver%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EPermitir%20que%20se%20apliquen%20permisos%20a%20publicaciones%20individuales.%20De%20esa%20manera%2C%20un%20usuario%20puede%20colocar%20contenido%20similar%20en%20una%20sola%20carpeta%20o%20en%20un%20conjunto%20de%20carpetas%20y%20compartir%20solo%20las%20publicaciones%20que%20sean%20relevantes%20para%20las%20personas.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3E%C2%BFPor%20qu%C3%A9%20es%20importante%20esta%20idea%3F%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3EGestionar%20un%20mayor%20n%C3%BAmero%20de%20informes%20en%20otro%20software%20es%20dif%C3%ADcil%20y%2C%20francamente%2C%20simplemente%20no%20sucede.Dar%20m%C3%A1s%20flexibilidad%20sobre%20c%C3%B3mo%20se%20organizan%20las%20publicaciones%20har%C3%A1%20que%20sea%20un%20poco%20m%C3%A1s%20f%C3%A1cil%20evitar%20que%20jmplive%20se%20llene%20de%20publicaciones%2C%20carpetas%20y%20espacios%20antiguos.%3C%2FP%3E%0A%3CP%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-673386%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EAcceso%20a%20los%20datos%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-680552%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3ERe%3A%20JMP%20Live%3A%20Permisos%20de%20nivel%20posterior%20-%20Estado%20cambiado%20a%3A%20Reconocido%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-680552%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E
JMP Live: Post-level permissions
Often small ad-hoc groups across teams want to explore data together.  Today these need to be in separate spaces, eventually they can be in separate folders, but in both cases that means the only way to organize posts is based on permissions.
Allow permissions to be applied to individual posts. That way a user can put similar content in a single folder or set of folders, and only share the posts that are relevant to individuals.
Why is this idea important?
Managing larger numbers of reports in other software is difficult and frankly just does not happen.  Giving more flexibility over how posts are organized will make it just a little easier to keep jmplive from being cluttered with old posts, folders, and spaces.
1 Comment
dieter_pisot
