  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
JMP 19: Change Default Column Search from "Contains Phrase"
I just upgraded to JMP 19.  Now every table that I open I have to click the little drop down box next to the Filter text box on the column pane and select "Contains Terms" instead of "Contains Phrase".
Please add a Preference to se the default Column Search to one of the options other than "Contains Phrase".
15 Comments
Sarah-Sylvestre
Level V
Thank you for submitting this request!
hogi
Level XIII
FYI: "Contains Terms" was the default up to now.
The new options are cool, but changing the default from one version to another : why ?!?
YES, A setting in the preferences will be very helpful!
Please also add a preference for "Match All terms" - just imagine how powerful the function will get with Match all terms disabled!
hogi
Level XIII
Hi @Sarah-Sylvestre , are the topics "Preferences for the Filter mode" and "preferences for Match all Terms" added to the internal JIRA tracking?
caseofmondays
Level III
I would like this to be changed back (or have a default preference added) for this as well.
Sarah-Sylvestre
Level V
Hi @hogi, we are aware of all the feedback, thanks for checking!
hogi
Level XIII
BHarris
Level VII
Would love an option to always treat the entry as regex!
AGhilioni
Level I
I always use the "Regular Expression" option, it is bothersome to always aim for that tiny little triangle... I would love the option to persistently customize that selection
GianpaoloP
Level I
Please use "contains Term" as default
NormalBison4848
Level I
Please use "contains Term" as default or allow for a global Preference setting
