JMP 19: Change Default Column Search from "Contains Phrase"
I just upgraded to JMP 19.  Now every table that I open I have to click the little drop down box next to the Filter text box on the column pane and select "Contains Terms" instead of "Contains Phrase".
Please add a Preference to se the default Column Search to one of the options other than "Contains Phrase".
8 Comments
Thank you for submitting this request!
hogi
Level XIII
FYI: "Contains Terms" was the default up to now.
The new options are cool, but changing the default from one version to another : why ?!?
YES, A setting in the preferences will be very helpful!
Please also add a preference for "Match All terms" - just imagine how powerful the function will get with Match all terms disabled!
hogi
Level XIII
Hi @Sarah-Sylvestre , are the topics "Preferences for the Filter mode" and "preferences for Match all Terms" added to the internal JIRA tracking?
caseofmondays
Level III
I would like this to be changed back (or have a default preference added) for this as well.
Hi @hogi, we are aware of all the feedback, thanks for checking!
hogi
Level XIII
BHarris
Level VII
Would love an option to always treat the entry as regex!
AGhilioni
Level I
I always use the "Regular Expression" option, it is bothersome to always aim for that tiny little triangle... I would love the option to persistently customize that selection
