In Graph Builder plots, Control-Click on Y-axis Should Not Propagate To X-axis
I frequently make multi-page XY plots  using Graph Builder.  By default, JMP sets the X-axis and Y-axis labels based on the column name in the source data table.  However, I very frequently find I no not want the data column name to be used for the Y-axis label.  For example, the column name might be "Decay_Rate_Under_TestMode_Z5BRD6".  I want the Y-axis label on ALL of the multi-page plots to simply read "Decay Rate".  The EASY solution is to press Control-Click (in Windows 11) on the Y-axis label and then enter the desired Y-axis label.  And it works!  But...it also propagates that new Y-axis label onto to ALL of the X-axis labels.   This is frustrating!  Worse, I could swear that I've done this before and had things NOT work out this way.
In Graph Builder with multiple "page" plots, I should be able Control-Click on an axis label, enter a new label text, and have the new label text propagate across ALL plots but only for the selected axis (e.g., only for Y-axis labels).  It should NOT propagate to the other axis label.
Why is this idea important?
This is important because...I waste an inordinate amount of time trying to fix this issue of unintended propagation of the new axis labels to the other axis.  This request is so obvious that I am actually assuming there is already a way to accomplish what I am requesting.  If so, JMP hides it well!  If not, then this is another case of JMP getting in the way of getting things done rather than helping get things done.
