When adding covariate factors in Custom Design, there is no option for bringing an additional column of row labels from the covariate source into the resulting design table. Although the "Covariate Row Index" column is helpful, this column is only included when a subset of covariate rows is selected; when all covariate rows, the row index column is not included in the design table. Even when it is, a row index from the covariate table is not as good as having a meaningful label.
When adding covariate factors from an external data table in Custom Design, give users the option to also select a label or ID column from the covariate table. This column would then be included in the generated design table with role/modeling type set as None/Label, and excluded by default from the Model outline.
Why is this idea important?
When executing runs in practice, experimenters need clear identifiers (labels, IDs, and source row numbers) directly in the run sheet to map each run back to the covariate source table without having to work around it via post-hoc joins or by adding IDs/labels as covariate factors.
