%3CLINGO-SUB%20id%3D%22lingo-sub-82710%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EActualizaci%C3%B3n%20de%20solicitud%20HTTP%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-82710%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EEstaba%20trabajando%20en%20un%20problema%20al%20utilizar%20la%20nueva%20solicitud%20HTTP.%20Cuando%20se%20espera%20que%20un%20punto%20final%20de%20API%20devuelva%20texto%20%2F%20html%2C%20la%20nueva%20solicitud%20HTTP%20actual%20requerir%C3%ADa%20que%20el%20usuario%20descargue%20el%20archivo.%20Creo%20que%20ser%C3%ADa%20%C3%BAtil%20si%20el%20mensaje%20enviado%20fuera%20capaz%20de%20aceptar%20argumentos%20%22blob%22%20o%20%22texto%22.%26nbsp%3B%3C%2FP%3E%3CP%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FDiscussions%2FAPI-Response-Encoded-as-Gzip%2Fm-p%2F82704%23M37256%22%20target%3D%22_blank%22%3E%20https%3A%2F%2Fcommunity.jmp.com%2Ft5%2FDiscussions%2FAPI-Response-Encoded-as-Gzip%2Fmp%2F82704%23M37256%20%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-82710%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EAcceso%20a%20los%20datos%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-560919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Actualizaci%C3%B3n%20de%20solicitud%20HTTP%3A%20estado%20cambiado%20a%3A%20archivado%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-560919%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EEstamos%20archivando%20esta%20solicitud.%20Si%20sigue%20siendo%20importante%2C%20comente%20con%20detalles%20adicionales%20y%20la%20volveremos%20a%20abrir.%20%C2%A1Gracias!%3C%2FLINGO-BODY%3E
HTTP Request Upgrade
I was working on a problem using the  New HTTP Request. When an API endpoint is expected to return text/html, the current New HTTP Request would require the user to download the file . I believe it would be helpful if the send message was capable of accepting "blob" or "text" arguments.
https://community.jmp.com/t5/Discussions/API-Response-Encoded-as-Gzip/m-p/82704#M37256
1 Comment
Ryan_Gilmore
Community Manager
Status changed to: Archived
