Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
In our analysis, we would like to be able to add in our graphs (Variability Charts, Distributions...) a new parameter : " Test Limits". Today, we have found no solution in JMP16.2 to perform this operation.
We would like to have a new column property which would allow us to add the new parameter "Test Limits" with low and high values so that it could be added to the graphs like the Spec limits.
Why is this idea important?
During our reporting our analysis to both Development and Production teams, this improvement would allow us to show and check that "Test Limits" are correctly set in production regarding the types of Design specs (gaussian, non-gaussian parameters, leakages...).
