JMP Wish List
Give us (scripters) a way to prevent reports from being snapshotted when scripting
Writing scripts and finally this post How to supress script dump in log upon closing a chart?
1. Message / argument to prevent report snapshot from single report
I would like to see a message we can use to prevent a platform from being recorded when it is being closed which we could use when scripting. The message could be something similar as the preference we have
<< Report Snapshot On Close(0)
and of course it should be possible to use this as an argument in JMP Platforms.
2. A function which would change how snapshot behaves in current script
Being able to disable all snapshots created from a script could also be useful. The setting could work in similar manner as Names Default To Here(1); and maybe it could be called something like
Disable Snapshot On Close(1);
Why is this idea important?
When writing and using custom scripts it can get quite annoying when your log is being spammed with report snapshots. This can be already prevented by modifying preferences but I would like to keep preferences as they are as I like that snapshots are saved when I'm using JMP interactively and just prevent these snapshots from my scripts. There is also at least one workaround which works from time to time but this is very clunky to start adding to every report
dt = open("$SAMPLE_DATA/Big Class.jmp");
nw = New Window("", gb = dt << Graph Builder(
	Variables(X(:weight), Y(:height), Overlay(:sex)),
	Elements(Points(X, Y, Legend(9)), Line Of Fit(X, Y, Legend(11)))
nw << on close(
	gb << close window;
3 Comments
hardner
I'm still looking into this but maybe seeing some significant speed issues involved with this logging for certain reports.
Strongly agree with wanting to be able to avoid it without altering the preferences of script users.
nathan-clark
I like this idea and I would like it to extend to beyond just reports. There are so many things that get logged automatically that just clog the log or slow things down. While 99% of the log stuff is amazing and useful, etc, giving us control on when we don't want stuff put in the log would be great.
ben_ph
I have seen that larger custom reports can take quite a long time to have their snapshot logged on close during which JMP becomes unresponsive. The resulting code in the log is always truncated and can not be run. For very custom reports it is also unlikely that the code would work even if it were complete.
The first proposal
 would be great to have available when calling NewWindow for a complicated report.
