Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
Could you provide some example .EPS files that you'd like to import? Generally speaking .EPS files are graphics files. How would you like to use these files in JMP?
Thank you for your comment and seeking more clarification.
I receive them (.EPS) from one of our clients and need to open and check (QC) whether they are in publication ready or not. If Yes, i might do some changes and save them in .EPS and will be shared back to them.
Thanks for the follow-up. I'm not sure whether that kind of interaction with EPS files will be possible to incorporate in JMP but it's helpful to know what you're looking for.
