Fix JMP Graph BY to include ID of the BY being plotted
When subdividing multiple graphs using BY, the current behavior does not label each graph with the BY result being plotted.
Revise the graph BY to show a label (similar to how PAGE does at the top left above a graph) for the BY value being plotted in the associated graph.
Why is this idea important?
This will allow better identification of what criteria is being used for each plot.
3 Comments
Status changed to: Needs Info
@GraphOTE please can you provide an example of what you are looking for. Thank you.
GraphOTE
Level I
Using the training data set "Fancy Chocolate Factory",  the PAGE feature puts the titles (e.g. Product=Milk Chocolate, Product=  Dark Chocolate, Product= Extra Dark Chocolate) just above each graph.
BY puts that information at a higher level off to the left so it is not as obvious what each graph represents.
I see now that turning off the CONTROL PANEL for each of the BY graphs will give an equivalent display.
Sorry, I had not used BY much and should have experimented more before submitting this suggestion.
You can close this entry.  I would withdraw it, but I don't see a way to do so.
Thanks for your time.
Status changed to: Archived
