Fit Life by X plot - modify scales to account for Use Condition
What inspired this wish list request? When a use condition is specified, and one wants to view a graph at those conditions you have to manually change the scales.
What is the improvement you would like to see? The X and Y scales should offer an easy to update method to be updated for the Scatterplot, Nonparametric overlay and other plots if a Use Condition is specified at the dialogue or if one uses the Red Triangle and chooses Set Time Acceleration Use Condition. f I have a Set Use condition and choose to show my Density Curves, I do not see the Density Curve for the use condition unless I manually rescale the X and Y axes. This is not normal JMP quality.
Why is this idea important?  Will provide faster insight into the results and help standardize output for these type problems.
