JMP Wish List
Enhanced dashboard drilldown
When developing dashboards for JMP Live that contain large numbers of products with significantly different run rates, the visualizations can quickly become noisy and difficult to interpret. This is especially true when multiple products share the same equipment or manufacturing track.
For example:
  • Product A runs approximately 5 lots per week
  • Product B runs approximately 79 lots per week
  • Product C runs approximately 2 lots every 5 weeks
All three products run on the same equipment track. While the dashboard correctly displays the full population of data, the large differences in run frequency can cause the higher-volume products to dominate the visualizations. This makes it difficult for users to focus on lower-volume products or perform targeted outlier analysis.
Users often request the ability to isolate or filter specific product populations within the dashboard so they can investigate trends, anomalies, or performance issues without the noise from unrelated data.
An enhancement that would allow users to interactively select or filter subsets of data directly within a JMP Live dashboard would significantly improve usability. Ideally, this would include the ability to:
  • Select specific regions of a graph (such as lasso or box selection) to dynamically filter the dataset
  • Filter by product, equipment, or other categorical variables directly from the visualization
  • Update all linked graphs in the dashboard based on the selected subset
This type of interactive filtering would allow analysts to quickly narrow down to the most relevant population without needing to create multiple versions of the same dashboard.
Why is this idea important?
Interactive filtering would make dashboards more effective for both analysis and communication. Analysts could quickly isolate specific product populations for outlier investigations, while operational teams could view the data most relevant to their work.
This would improve usability, reduce the need to create multiple dashboards for different product groups, and make it easier to communicate insights during pass-down discussions and team reviews. Overall, it would allow teams to work more efficiently with large and diverse manufacturing datasets.
2 Comments
CriticalSeal493
I was just about to make the same wish list for dashboard development in JMP :D!
I concur with this idea, in fact I would like to further suggest that JMP could possibly extend itself as a customizable dashboard development in journals through greater control over integrating different data tables, report structures and better support such as in the form of workflow builder being able to record and capture such dashboard development and customization can be built through the use of JSL and/or python integrated environment.
However, I do concede that development of a dashboard heavily demands newer complex resources and optimization routes to remain accessible to a majority of users and its development in of itself are entire enterprises work scope so it will not be easy or fast to develop.
Nonetheless, I believe the end goal of analysis is a mix of collaborative and critical decision making, JMP analyses should have the resources available and accessible to output both complicated and simple visual data analysis to achieve these user goals.
Sarah-Sylvestre
Thank you for taking the time to submit this request!
