Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
Currently, code folding is not supported for messages, platforms, user-defined functions, and comments. Instead of a jmpkeyword.jsl option, a JSL advanced option to Collapse All Comment Blocks would be a very nice to have.
I would think additionally about code folding assignments, e.g. a string covering several lines, or adding scripts to tables (that have many lines). Usually I help myself adding an expression and evaluating it, this makes the code much better readable. See examples.
sql_string =
select
from
dual
dtc << new script(
"__newscript__",
Names default to here(1);
wait(1);
wait(1);
This is very cool. Extensive comment blocks, those that apply context, assumptions, pseudo-code and references can be quite useful for training and just updating and testing old programs. Thank you JMP developers!!
