DOE Color Map on Correlations
I would like to request the following additions for the Color Maps for Correlations in the DOE platforms:
- Currently, the Special Purpose designs (e.g., Space-filling) do not have the option to generate a color map for correlations, unlike more traditional platforms such as Custom DOE. Can this be added?
- When using the Compare Designs platforms, the color map block does not have a hot-key menu to change the color scheme from grayscale to blue-gray-red. Can this feature be added? I understand that there is currently a workaround available to customize the color scheme from the menu obtained when right-clicking on the map.
Thanks and regards
Mehul Shroff
cc: @PatrickGuiliano
