Custom design from candidate points
There is two main schools of how people can build DOE. The one chosen by JMP is to create design matrix using the powerful coordinate exchange algorithm. The second way is to provide a list of candidate data points (that could respects some complex constraints) and then search through it to create the design. (Actually, is JMP creating this list of candidate points in background ? When looking at design, there are some weird non rounded values, some times, which seems to indicate that JMP can take really any point (satisfying constraints if any) from the space of factor.)
I discussed yesterday with many DoE users at a conference, and they told me the fact that the second option does not exist in JMP is one of the main reason they don’t want to buy and use JMP. This option is however available in SAS proc Optex, which I am sure share many similarities with the Custom DoE platform of JMP.
Would you think such addition may be possible in the future, for Custom Design and Augment Design platforms ?
5 Comments
Phil_Kay
Have you seen that you can define Covariate factors in Custom Design? https://www.jmp.com/support/help/en/15.2/index.shtml#page/jmp/experiments-with-covariates.shtml
This enables you to specify factors for the experiment from a table of candidate runs.
plebrun
Thanks for this. It seems it can allow to use only covariates then (use the table as candidate list) and I can do that without adding any factors from the ones available in the candidate list.
So it helps, even if it was not clear from the help
Pierre
Phil_Kay
Yes, you can design an experiment with factors only from the candidate table, if you wish.
Look out for changes to the interface for this in the next version of JMP.
plebrun
Thanks Phil, Excellent news. This could be made more visible. I can't wait for V16 then
Enjoy,
Pierre
Ryan_Gilmore
Community Manager
Status changed to: Archived
We are archiving this request. If this is still important please comment with additional details and we will reopen. Thank you!
