JMP Wish List
Control chart builder sort by reverse row order option
I would like to suggest adding in an option to sort by the reverse row order as well as the current option to sort by row order in control chart builder.  Many times the data is in the correct time order just starting from newest to oldest which then needs the the option to sort by the reverse row order for the control charts to be aligned correctly.
Also, both these options would be great to add to the process screening platform.
Thanks for considering this request.
Steve
2 Comments
SamGardner
Status changed to: Needs Info
Hello @shampton82 .  Thanks for the suggestion.  Have you considered added an row ordering numeric column to the data table?  If you do that, then you can use that column on the X-axis, or alternatively sort the data based on the column prior to using Control Chart Builder or Process Screening.
shampton82
Thanks for suggestions Sam!  Yeah I have played around with those options and they will work until we get the easy button.
Steve
