Bulk Comparison Analysis, MSA
What inspired this wish list request? Please describe the current issue that needs improvement or the problem to be solved that is not easy or possible right now, with an example use case.
Often you conduct comparison and MSA over hundreds of characteristics or columns.
In the MSA output, f y/x, variability chart, matched pairs add an output similar to the "Process Screening" platform. So you can review across many columns the specific parametric data, and focus on those that are significant.
As is, in these platforms, you cannot screen results. It would be very helpful to be able to screen these results.
1 more suggestion, in response screening, allow you to factor in spec limits and percent of tolerance shifts, in addition to fit / Rsq significance.
What is the improvement you would like to see? Please describe the idea for improving JMP. Please include mock-ups, wireframes, screenshots, scripts, other documents or examples from other software that help describe the change you would like to see.
Why is this idea important? Please describe the value to you and/or other users if the idea is implemented (for example, ease of use, must have,…).
