Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
try File->New->App Builder. It looks/works similar to the VB tool. I've built some multi-window applications with it. It has more than one personality, you might want to start with the empty application, depending on your goal.
Hi @ThuongLe - as Craige points out there are several personalities to the Application Builder. If you are arranging a single window consisting of platforms, data filters, data tables, text, and images, you might consider using a Dashboard personality. Like a platform, you can deploy this to a data table or add-in without editing any of the JSL. The JMP Application personality opens up more functionality - individual input boxes with custom JSL actions, multiple windows, and more.
There are examples and notes in the tutorial from JMP Discovery last year. If you are attending the virtual JMP Discovery this week, stop by breakout room 23 in Meet-the-Developers and I'll walk you through a few examples.
