  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Bootstrapping by group
What inspired this wish list request? The right-click bootstrap feature is not currently available in reports that use by-group processing. If one wants to run bootstraps on multiple subsets of data, rows in the data table must be manually included/excluded and run as separate distributions.
What is the improvement you would like to see? The right-click bootstrap feature becoming available in reports that use by-group processing would be a major time saver and help reduce manual filtering errors when subsetting the data for each group's bootstrap.
Why is this idea important?  Bootstrapping is a tool my colleagues and I use regularly while writing reports. It would save a lot of rework and, again, truly reduce manual filtering errors when subsetting the data for each group's bootstrap.
1 Comment
mia_stephens
Thank you for submitting this request @mathstat2032, we will take this under consideration for a future release. In the meantime, the global data filter (Rows > Data Filter) can be used as an alternative to subsetting. Alternatively, the script shared by Technical Support can be converted to an add-in where users can pick tables and variable names.
@tom_donnelly FYI.
