Be able to size a datatable when it is invisible
I have scripts that create a bunch of tables that I open as invisible to keep the screen clutter down for the end user.  However, I when the user clicks on the tables the default table size is not big enough and they have to resize them.  Reviewed this issue with tech support case: 00062381.
I would like to see the ability to set a data table window size when opening a file as invisible.  Like you can with a new window:
Why is this idea important?
This will allow the user to not have to resize data table windows that are brought into JMP as invisible and remain invisible until the user needs to use the datable.  This can be an annoying time suck if there are many tables.
