Allow style edits of USL etc lines on graphs (graph builder, control charts etc) to be saved as a platform wide preset
When making a graph (e.g. using graph builder), any saved spec limits can be shown as reference lines. The default is a light blue, thin line which is often too thin to see easily (especially when copying graphs for a presentation).
On a per graph basis the thickness/colour etc can be changed (by using the axis settings) but this takes a long time for many graphs (for example if many control charts are made).
When saving a script the changes are saved, but they then no longer update if the spec limits are changed later.
Any new graphs also have to be edited manually each time.
Allow a platform wide preference for spec limit reference lines (colour/thickness etc). This could be saved as part of the new "platform presets" or as an install-wide preference?
Why is this idea important?
This would make the spec limit feature more useful and let graphs be easier to understand visually.
1 Comment
Thank you for sharing this request!
