Allow secondary or alternate column names
Store alternate column names or attributes, be able to switch between those names in platforms and the data table, and easily view those names while hovering over the column name or points.
While moving through exploratory, modeling, and presentation phases of work it is helpful to name columns differently, for example depending on the audience and context a column could be represented as any of the following or more.
  • Unit98765.Tag12345.SP
  • Feed Flow Controller Set Point
  • Feed Flow Controller Set Point (Unit98765.Tag12345.SP)
  • Feed Flow Controller Set Point (m3/s)
Especially while working in JMP with an audience (for example answering questions with ad-hoc analyses during a presentation) it is helpful to have as much info about columns accessible with as few clicks as possible, but these tools could speed up work for all users.   Common places this would be handy include these activities for data tables with hundreds or thousands of columns:
  • Search for columns when picking columns in graph builder, and verify the correct column was picked
  • Default names in graph builder
  • Column contribution, variable importance, and similar tables
15 Comments
hogi
Level XIII
Column Name Alias could provide a list of values - (e.g. for different languages, different types of plots)
In a graph, the user can select "use column name alias" with an index.
Independent of this additional feature, I hope Column Name Alias will make it into JMP19 :)
hogi
Level XIII
hogi
Level XIII
Thanks.
Will be very helpful for data curation - and reloading.
hogi
Level XIII
