Add non-parametric test for response screening platform
What inspired this wish list request? There is only one test available in the platform response screening: seems to be ANOVA that gives the pvalue testing the effect of X on response Y.
What is the improvement you would like to see ? It should be great to have non-parametrical test such as Wilcoxon test or other, or the choice of the test to be done in order to get the advantages of controlling the false-discovery rate when multiple tests.
Why is this idea important ? It's important to improve the statistical theory behind "Pvalue" output of this platform which do not give any information on the test done, that seems not adpated to different distibutions of X or Y.
2 Comments
mia_stephens
Thank you for submitting this request @carole. It's getting some kudos!
Hello @carole , Response screening contains in the advanced options robust fit and Cauchy Fit to reduce the influence of outliers. You will find the explanation here Launch the Response Screening Platform. Would that help to resolve your request?
