JMP Wish List
Add new << Calculate Values() function
Add new function which would return values in a list (or matrix if numeric calculation) based on column calculations. We can calculate values with Formula() and << Set Each Value, but we have to place the values in Data Table. It would be nice to be able to just calculate values based on the data table's columns WITHOUT adding new columns which you will have to later remove.
One idea for usage could be something like this (Big Class.jmp)
result = dt << Calculate Values(:Height / :Weight);
and this would then return me a matrix with :Height/:Weight calculated for each row.
Other example with characters could be
result = dt << Calculate Values(:sex ||"_"||Char(:age));
and this would return me a list of each row concatenated with :sex and :age.
1 Comment
Level XIII
Workaround:
use a transform column as a dummy to calculate the values.
Then no real column is added to the data table.
