  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Add medoid clustering
What inspired this wish list request?  I would like to run clustering where the cluster centers (medoids) are restricted to be rows in the data table (different from kmeans where the mean may not be a row in the table and satisfy constraints).
What is the improvement you would like to see?  Perhaps add this somewhere in the Analyze > Clustering menu. Here is some example R code.
library(cluster)
n <- 200
X <- data.frame(
  x1 = rnorm(n),
  x2 = runif(n, 0, 10),
  f1 = factor(sample(letters[1:3], n, TRUE)),
  f2 = factor(sample(c("lo","mid","hi"), n, TRUE))
d   <- daisy(X, metric = "gower")
fit <- pam(d, k = 5, diss = TRUE)
cl <- fit$clustering
medoid_rows <- fit$id.med
cat("Medoid row indices:", medoid_rows, "\n\n")
cat("Medoid rows (one per cluster):\n")
print(X[medoid_rows, ], row.names = FALSE)
cat("\nCluster sizes:\n")
print(table(cl))
Medoid row indices: 170 111 191 200 68
          x1       x2 f1  f2
 -0.42460961 4.116528  b mid
 -0.08807738 7.593479  b  hi
 -0.32078302 2.121084  c  lo
  0.28653902 4.962979  c mid
  0.30942313 2.652641  a  lo
Cluster sizes:
> print(table(cl))
cl
 1  2  3  4  5
33 43 43 35 46
Why is this idea important?
I want to use this on tables produced by Output Random Table in Profiler to downselect a subset of different highly desirable factor settings, and need this instead of k-means for when mixture or other constraints are present.
1 Comment
SarahGilyard
This is an interesting suggestion. We will discuss internally. Thank you for posting.
